kanchanjoshi
simple copy paste frm jmp to Excel not happening completely
Hi
Help! Please let know if this is some kind of a bug: I just tried to do a super simple copy paste of 2000 cells in a column in jmp to Excel and only 1600 get pasted in Excel
The same operation has no issue for other two columns where all 2000 cells get pasted.
Thanks
rsafadi
Re: simple copy paste frm jmp to Excel not happening completely
i have same issue with jmp15 and excel 2016
when copying 300-400 cells from excel into jmp15 , it will hang and freeze
using version 15 with latest updates.
after i kept having that problem i uninstalled jmp15 and installed jmp14 and had no issues preforming the exact same thing.
something is wrong with jmp15 , please fix.
mzwald
I'd recommend you email technical support (support@jmp.com) with an anonymized version of your excel spreadsheet.
I copy/paste data from Excel into JMP 15 and have never encountered this issue.
Thierry_S
Just a few questions to see if I can figure out your problem:
1) Are you trying to paste 2,000 cells horizontally (i.e. 2,000 columns) [I think that Excel has a maximum of ~1600 columns]?
2) If you save the file as an Excel file (Save As > Excel) and open it in Excel do you have the same problem?
Best,
TS
Thierry R. Sornasse
