Subscribe Bookmark RSS Feed
how to specify colors in line plots for many columns (lines)
paul_tanger140
May 20, 2015
I'm creating a line graph with MANY (over 200 columns) of data, each of which is a line in my plot (continuous variables plotted to y axis, and categorical (rows in table) plotted on x axis. Something like this:
Everything looks good so far, but how do assign the colors for each line instead of the JMP defaults?  Is the only way right click on the graph and select "customize" and then change the color for each line?  Because when I do that with my giant graph I get this error "menu item overflow".  Hopefully there is a way to do this for each column back in the data table before the graph is created?
Thanks!
ms
Jun 23, 2011
A quicker way than Customize is to select one, all or any combination of lines (shift-click to select ranges, cmd/ctrl click to select discontinuously) in the legend and then right-click to select color.
The multiple selection of legend items appears to require JMP 12.
paul_tanger140
May 20, 2015
Thanks, is there a solution for JMP11?  I don't have 12.
robot
Feb 27, 2012
Are you using Graph Builder?  If yes, one can change color by right-clicking the desired variable on the graph legend in JMP11.  A script may look something like this:
graph = dt << Graph Builder(
  Show Control Panel( 0 ),
  Variables(
  X( :age ),
  Y( :height ),
  Y( :weight, Position( 1 ) ),
  Group X( :sex )
  Elements(
  Line(
  X,
  Y( 1 ),
  Y( 2 ),
  Legend( 2 ),
  Row order( 0 ),
  Dispatch(
  "400",
  ScaleBox,
  {Legend Model(
  2,
  Properties( 0, {Line Color( 6 )} ),
  Properties( 1, {Line Color( 8 )} )
XanGregg
Jun 23, 2011
Another way is to set the Value Colors property on the Overlay variable. That will override the JMP default colors, and the Value Colors dialog supports multiple selection in older JMPs. And if you're doing this for multiple similar columns, you can use Standardize Attributes to change them all at once.
