lwx228
Level VIII
Using JSL to download Web JSON data, can be directly written into the matrix?
A table in all digital format can be downloaded using the following JSL.
u = "http……";
txt = Load Text File( u );
loc1 = "[{";
offset = Contains( txt, loc1 );
If( offset,
	txt = Substr( txt, offset, Length( txt ) )
loc2 = "}]";
offset = Contains( txt, loc2, -1 );
If( offset,
	txt = Substr( txt, 1, offset + 1 )
d1 = JSON To Data Table( txt );//without going through a "d1" file.
How to write the data directly into the matrix without going through a "d1" file.
Thanks Experts!
Craige_Hales
Re: Using JSL to download Web JSON data, can be directly written into the matrix?
What problem are you trying to solve? The download time will be 100 times as long as the conversion from table to matrix.
Craige
lwx228
Level VIII
OK.
table to matrix.
Thank Craige!
