hogi
Level XIII
User Defined Functions with Expression arguments
In JSL there are many functions which allow Expressions as arguments, like
dt << New Column( "X", Formula( row() ) );
where the supplementary argument Formula( row() ) can be at any position (N>1) within (...) because it can be identified via the keyword
Formula().
Can user-defined functions have similar supplementary arguments?
Craige_Hales
Re: User Defined Functions with Expression arguments
No. The user defined function always evaluates the arguments that were passed before putting the values into its local parameters.
You could use expr(), but a list is a better choice: myfunc( "X", { formula( row() ) } ). I used that somewhere recently, and it worked well; variables inside the list still need to be evaluated, and myfunc finds them in the proper calling context. (Assuming no collisions between the caller names and myfunc names...) I think I used a single list and took advantage of nitems() as well.
Craige
hogi
Level XIII
Thanks @Craige_Hales , the workaround with the list - brilliant :)
Hm, worth to write a post for the wish list?
Ah, there is one:
Keyword arguments for functions
