Subscribe Bookmark RSS Feed
Script - Filter
seyberg
Nov 17, 2011
I'm having an issue with scripting a data filter.  I want to create a script where I make a data filter which excludes/hides some data, runs a graphing function, unexcludes/unhides all data, then closes the filter window.
What I have so far is,
obj = Current Data Table() << Data Filter( Add Filter(  /*     Filter Conditions        */ ));
/*    Graphing Function     */
obj << Clear;
wdw = window("Data Filter <File Name>");
wdw << closewindow();
This is a working solution but only while the file name is exactly as created.  Is there a way to generalize the file name?  Alternately, another method of closing the data filter window would also fulfil my needs.
David_Burnham
Jul 13, 2011
First of all sorry if I am misunderstanding what you are trying to do, but I get the sense that you are trying to use the data filter to automate the exclusion of data points in preparation for making a graph without using it interactively.  The data filter is just a convenient user-interface tool for controlling the hide and exclude row states - if you are not using the filter interactively it may be easier to just script these row states directly:
obj = Current Data Table();
sel = obj << Select Where( /* filter conditions */ );
sel << Exclude;  /* exclude selection */
/* graphing function */
sel << Exclude; /* toggle-off exclude selection */
Dave
-Dave
David_Burnham
Jul 13, 2011
For the purposes of correctness, the data filter operates the reverse to row states (i.e. it uses show and include whereas the row states are hide and exclude) so in my example above the selection should be inverted:
sel << Invert Row Selection;
-Dave
seyberg
Nov 17, 2011
That is correct.  The ideal is for another JMP user to reach the end analysis from any table form (exclusions, selections), run graphs, then clear back to the table default.  I'm having trouble getting this script to recognize multiple conditions, at least by writing it in as I would in the filter function like so.
        columns( :Condition 1, :Condition 2),
        Where( :Condition 1 == {"A", "B"} ),
        Where( :Condition 2 == {"C", "D"}) ),
Mode( Select( 0 ), Show( 1 ), Include( 1 ) ) );
How would this filter be translated into script?  And how do you clear selection?
David_Burnham
Jul 13, 2011
The code that you are writing is generated from the data filter by selecting the option Script>Save Script to Script Window e.g.
          Location( {638, 47} ),
          Add Filter( columns( :age, :sex ), Where( :age == 12 ), Where( :sex == "F" ) )
To get a JSL specification of the where clause you can use the option Save Where Clause>to Script Window e.g.
Select Where( :age == 12 & :sex == "F" );
The programmatic equivalent of pressing the Clear button on the data filter is to write
obj << Clear Row States;
where obj is a reference to the data table.
Dave
-Dave
seyberg
Nov 17, 2011
Thanks a ton Dave!  I think I have it figured out from there.
