lwx228
Level VIII
How to get multiple open data table file names for JSL?
Hi:
Assuming that two datatable files have been opened but no table Numbers have been entered in advance, how do can get multiple datatable file names that have been opened?How to jump from the current file to another file?Thank you!
Re: How to get multiple open data table file names for JSL?
You can find out the number of open tables with the N Table() function, and then get each name by looping through the open tables and asking for each table's name
For( i = 1, i <= N Table(), i++,
	Show( Data Table( i ) << get name )
Below is one example of how I deal with the need to point directly at a data table, which allows one to switch between them.
dtLIst = {};
	dt = data table(i);
	insert into(dtList, dt );
eval(dtList[1]) << new column("added column", set each value(5));
dtList[2] << bivariate();
hardner
This ability may be newer than this thread but since I was just searching out the syntax for this (and sometimes the community seems the easy place to search) I thought I'd note here that there is a function GetDataTableList() to directly get a list of open table names.
dtLIst = {};
	dt = data table(i);
lwx228
Level VIII
Thank Jim!
VBA:ActiveWindow.ActivateNext
hardner
lwx228
Level VIII
GetDataTableList() does not work if the table is already open.
So I'm going to use the Jim's method.
