Vinusha
How to deselect the columns that are assigned to Col List Box using Remove Selection Command
I have assigned a column to X Col Box(Col List Box) and on clicking the Remove Button I need to deselect the column that I assigned to it.
On X = Function({},
	X Col Box << Append(Cols List << Get Selected)
On Remove = Function({},
	X Col Box << Remove selected;
Re: How to deselect the columns that are assigned to Col List Box using Remove Selection Command
If you want to deselect column, you should use << Set Selected or << Clear Selection (<< Remove Selected will remove the item, not deselect).
New Window("Col List Box Example",
	lb = Col List Box(all, width(250), maxSelected(1)),
wait(1);
lb << Set Selected(2);
wait(1);
lb << Remove Selected();
Scripting Index does have examples how these can be used and there is documentation on JMP Help's Scripting Guide
