I've had this problem where part of the graph header areas is highlighted in black.
Within JMP looks normal but this happens when I try to past the image.
Copy results. In below case the "F" and "M" under sex can't be seen.
Have tried to look through the preferences but didn't find any setting that was off or one if toggled would fix the issue.
JMP version
