GregRupp
Create an IF statement that allows for multiple result outputs
I am trying to filter out data based on a value in a column either a 1 or a 0. I can get it to filter out the 1 or the 0, but I would also like to be able to show all columns both 1 and 0. I have tried varying things and they either come out with a range issue or an issue with it not being completely specified. The user has the ability to input in a radio box if they want 1, 0 or both, but I cannot get both to show up without an error.
(Current Data Table() << Data Filter(
Mode( Show( 1 ), Include( 1 ) ),
Inverse( 0 ),
invisible,
Add Filter(
    columns(:Fine),
     Where(IF(V=="Coarse", :Fine==0, V=="Fines",:Fine==1,V=="Both",:Fine >=0 ))))), //Coarse, Fines or Both are selected in a previous code that works well.
Re: Create an IF statement that allows for multiple result outputs
Below is an example taken directly from the Scripting Index.  It shows the syntax for selecting from multiple columns.  Please not that all columns that are to be selected on must be listed in the "Columns" element, and that the where clause needs to be set separatly for each column
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = dt << Data Filter();
obj << Add Filter( columns( :POP ) );
obj << Add Filter(
	columns( :Region, :State, :City ),
	Where( :Region == "S" ),
	Where( :State == {"SC", "NC"} )
GregRupp
Thank you for sharing this code with me. I tried the code in a separate script and see that it works the way I would like my code to. However it is not working for me, does this only work for nominal sets? I am still having a problem and with a missing range error.
The code now looks like the following:
Inverse( 0 ),
invisible,
Add Filter(
    columns(:Fine),
     Where(: Fine =={0,1}))));
an error says that the range is missing. Is there a function where I can set the range of a Column or Variable?
I have listed all of my columns in the "Columns" element and I have "Where" statements separate for all of my columns that I want to filter out.
Is your column named :Fine defined as a continuous column?  If it is Ordinal or Nominal your syntax is correct, however, if it is Continuous, the syntax is as listed below
	Location( {314, 74} ),
	Add Filter(
		columns( :age, :height ),
		Where( :age == {12, 14} ),
		Where( :height >= 58 & :height <= 66 ),
		Display( :age, Size( 160, 90 ), List Display )
GregRupp
My column (:Fine) is continous. If I understand correctly :height in this example is continous and you are setting a range. However, I am trying to set-up an "IF" statement in a "Where" statement.
	Add Filter(
		Where( If( x=="tall",:height >=72, x=="average",  :height >= 58 & :height <= 66, x=="Short", :height <= "58" ),  // x is selected previously in a radio box.
If I do something like this. It comes up with an error that says the "Where" clause has not been correctly specified 2 times.
