Image Isn't Everything, but It Sure Is Something in JMP® 9
John Ponte, JMP Software Developer – SAS
In the 1990s, the phrase “Image is everything!” became famous. With the release of JMP 9, images aren’t “everything,” but they are available in JMP. The new image functionality allows images to be used to improve visualizations, add context around data, and help you to extract data and information that were previously inaccessible in JMP. I’ll show you how to bring images into JMP and access the image-processing functionality through the user interface. I’ll also share some real-life examples of images and show how JMP Scripting Language can be used to extract the data for analysis. Come learn how JMP can improve your image and help you get to your data.
