David_Burnham
Super User (Alumni)
Paragraph Spacing
Here is an example post:
https://community.jmp.com/t5/JMP-User-Community-News/Welcome-to-the-JMP-User-Community/ba-p/28588
There is clearly a problem with paragraph behaviour.  I think the problem is that the editor is not WYSIWYG - therefore as I am typing, if I want a new paragraph then I do this:
... I press <enter> twice.  Why twice?  Because if I do it only once then I only get a new line like this:
But the trouble is that when the text is rendered as HTML a line break gets rendered as a new paragraph, and so the paragraph that we create with the double-enter appears as two paragraphs - hence the huge spacing.
-Dave
0 REPLIES 0
