%3CLINGO-SUB%20id%3D%22lingo-sub-708506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EProgettazione%20e%20analisi%20di%20esperimenti%20con%20miscele%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-708506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20questa%20sessione%20esploriamo%20come%20la%20sperimentazione%20su%20miscele%20o%20formulazioni%20%C3%A8%20diversa%20dalla%20normale%20sperimentazione%20di%20processo.%20I%20fattori%20di%20miscelazione%20sono%20unici%20in%20quanto%20la%20loro%20somma%20deve%20raggiungere%20il%20100%25.%20Questa%20restrizione%20influisce%20sulla%20progettazione%20dell'esperimento%2C%20sulla%20visualizzazione%20dei%20dati%20e%20sul%20modello%20statistico%20utilizzato%20per%20analizzare%20l'esperimento.%20Viene%20utilizzato%20un%20caso%20di%20studio%20per%20dimostrare%20come%20progettare%2C%20visualizzare%20e%20analizzare%20esperimenti%20con%20miscele%20in%20JMP.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Design and Analysis of Mixture Experiments
Workshop : Pre-conference
In this session, we explore how experimentation on mixtures or formulations is different from usual process experimentation. Mixture factors are unique in that their levels need to add up to 100%. This restriction affects the design of the experiment, data visualization, and the statistical model that is used to analyze the experiment. A case study is used to demonstrate how to design, visualize, and analyze mixture experiments in JMP.
This workshop takes place outside of the main Discovery Summit conference. It is not included with your registration fee.
Info
Fee: £
150 per day
Room: Whitworth 3
Authors
