Using Images for Processing and Analysis (2025-US-30MP-2306)
Images are an often-underutilized data source in analysis tasks. This presentation explores various methods for integrating images into JMP workflows, from importing and processing to use in modeling and experimental design.
Using a fictional case study approach, this presentation begins by showing how to create, import, and use images in JMP data tables. Next, a free JMP Marketplace extension is used to show how to isolate elements within images, calibrate colors and scales, and even perform measurements from within JMP. The presentation also shows how images (and information extracted from images) can serve as inputs or outputs in designed experiments in the FDE and Torch Deep Learning platforms in JMP Pro. Whether you work often with image-based data, or if you just need to extract the data from a graph in an academic journal, this session offers practical insights into making it easy and approachable to work with images in JMP.
Presenter
Schedule
2:00-2:45 PM
Skill level
- Beginner
- Intermediate
- Advanced
