Setting Robust Process Specifications Using Design of Experiments and Monte Carlo Techniques
William D. Kappele, President – Objective DOE
Setting specifications on process parameters can be a difficult job. Setting robust specifications that won't need constant adjustment may seem almost impossible. This presentation will show how a combination of design of experiments and Monte Carlo techniques can be used to set robust process specifications in a straightforward, objective manner. In an example using published data for a rubber manufacturing process, you will see stages of the process, from designing an experiment for optimizing the process specifications to the use of a Monte Carlo simulator to study the responses to specification changes. You will see these results used to optimize the process specifications. You won't need to delve into the math – JMP will handle that. You will leave this presentation with a new paradigm for setting robust process parameter specifications.
0 Comments
Published on ‎03-24-2025 09:06 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:58 AM
Start:
Tue, Sep 13, 2011 09:00 AM EDT
End:
Fri, Sep 16, 2011 05:00 PM EDT
