Level: Intermediate
Bradley Jones, JMP Distinguished Research Fellow, SAS
JMP 14 has several new DOE features. Perhaps the most important is a new design tool for creating balanced incomplete block designs (BIBDs). These designs have one treatment factor and one blocking factor. Each treatment level appears the same number of times overall, and each treatment level appears together with every other treatment level in some block the same number of times. This creates a special kind of balance. We will provide more details about this design and demonstrate the UI of the new tool.
The Custom Designer has added a pair of optimality criteria for generating A-optimal designs and weighted A-optimal designs. An A-optimal design minimizes the average variance of the parameter estimates. The A-criterion is similar to the well-known D-criterion, in that it focuses on the precise estimation of model parameters. There are two benefits to A-optimal designs. First, it is easier to understand how the A-criterion produces good designs than it is with the D-criterion, making it easier for new DOE practitioners to adopt. Second, weighted A-optimal designs allow for putting different amounts of emphasis on different groups of parameters. For example, one might want to emphasize pure quadratic effects over two-factor interactions and both of these over main effect estimation.
The Compare Designs tool can now accommodate up to five designs in the UI and up to 10 designs through scripting. Previously, the limit was three designs. We will demonstrate this additional capability with a UI example and a scripting example that includes the new A-optimal and weighted A-optimal designs.
Slide1.JPG Slide2.JPG Slide3.JPG Slide4.JPG Slide5.JPG Slide6.JPG Slide7.JPG Slide8.JPG Slide9.JPG Slide10.JPG Slide11.JPG Slide12.JPG Slide13.JPG Slide14.JPG Slide15.JPG Slide16.JPG Slide17.JPG Slide18.JPG
Published on ‎03-24-2025 08:52 AM by Community Manager Community Manager | Updated on ‎04-08-2025 09:07 AM
Level: Intermediate
Start:
Mon, Oct 8, 2018 09:00 AM EDT
End:
Fri, Oct 12, 2018 05:00 PM EDT
