Multiple Comparisons with JMP
Karen Copeland
Most practitioners are familiar with t-tests to compare two treatments, however, how should one compare more than two treatment groups?  The short answer is to use a multiple comparison procedure.  The longer answer is that it depends on what question you are trying to answer.  This poster will look at the multiple comparison procedures currently available in JMP8 as well as the ANOM (Analysis of Means) procedures that will be available in JMP9.
Published on ‎03-24-2025 09:07 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:58 AM
Karen Copeland
Event has ended
You can no longer attend this event.
Start:
Mon, Sep 13, 2010 09:00 AM EDT
End:
Thu, Sep 16, 2010 05:00 PM EDT
