JSL to the Rescue: Coping Strategies for Making Sense of Real-Time Production Data in Vaccine Manufacturing
Andrea Coombs, MS, Operations Research Analyst – Emergent BioSolutions
Emergent BioSolutions Inc. is a biopharmaceutical company that manufactures BioThrax® (Anthrax Vaccine Adsorbed), the only vaccine approved by the U.S. Food and Drug Administration for the prevention of anthrax infection.  BioThrax® production includes a two-stage fermentation of a non-virulent strain of Bacillus anthracis.  In-line turbidity, temperature, and pH probes are used to monitor the fermentation process and real-time data can be viewed remotely and is available for analysis.  JMP has been used to create a customized workflow to summarize data from multiple production trains.   A “super” journal is the command central of this customized workflow that contains JSL scripts to access, process, track and analyze data.  Central to this workflow are scripts to process real-time data into meaningful variables critical to the process, verify variables to ensure accuracy, and dynamic handling and visualization of data.  As a result, an overwhelming amount of real-time production data has been summarized into the key variables that have been used to monitor, characterize and improve the fermentation process.
Presented At Discovery Summit 2010
Presenter
Files
Published on ‎03-24-2025 09:07 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:59 AM
Event has ended
You can no longer attend this event.
Start:
Mon, Sep 13, 2010 09:00 AM EDT
End:
Thu, Sep 16, 2010 05:00 PM EDT
