Level: Intermediate
Jason Sheldon, Research Staff Member, Institute for Defense Analyses
The JMP Experimental Design Iterative Solver (JEDIS) is an add-in for JMP software that helps automate the design of experiments process within JMP in a user-friendly manner. JEDIS builds multiple test designs in JMP over user-specified ranges of sample sizes, signal-to-noise ratios (SNR) and alpha (1-confidence) levels. It then automatically calculates the statistical power to detect an effect due to each factor and any specified interactions for each design. When finished, JEDIS presents the statistical power versus design metrics in interactive plots and stores the data in an easy-to-use format. JEDIS supports generating factorial and optimal designs, but does not currently support generating split-plot designs. The JEDIS Light feature can compute power for a premade design table, including premade split-plot designs, over ranges of SNRs and alpha levels. Any version updates to JEDIS will be posted here .
Example using JEDIS for a Full Factorial DOEExample using JEDIS for a Full Factorial DOE Example using JEDIS for a Full Factorial DOE Example using JEDIS for a Full Factorial DOE Example exploring JEDIS plot optionsExample exploring JEDIS plot options Example exploring JEDIS plot options Example exploring JEDIS plot options
Slides (also attached):
Slide0.JPG Slide1.JPG Slide2.JPG Slide3.JPG Slide4.JPG Slide5.JPG Slide6.JPG Slide7.JPG Slide8.JPG Slide9.JPG Slide10.JPG Slide11.JPG Slide12.JPG Slide13.JPG Slide14.JPG Slide15.JPG Slide16.JPG Slide17.JPG Slide18.JPG Slide19.JPG Slide20.JPG Slide21.JPG Slide22.JPG Slide23.JPG Slide24.JPG Slide25.JPG Slide26.JPG Slide27.JPG Slide28.JPG Slide29.JPG Slide30.JPG Slide31.JPG Slide32.JPG Slide33.JPG Slide34.JPG Slide35.JPG Slide36.JPG
0 Comments
Published on ‎03-24-2025 08:52 AM by Community Manager Community Manager | Updated on ‎04-08-2025 09:07 AM
Level: Intermediate
Start:
Mon, Oct 8, 2018 09:00 AM EDT
End:
Fri, Oct 12, 2018 05:00 PM EDT
