Having Fun with SPC Using JMP® Scripting Language
Wenyu Su, Jeff Sweeney, and Wayne Zirk, The Dow Chemical Company
Statistical Process Control (SPC) is widely used at The Dow Chemical Company to investigate the process stability. JMP scripts are utilized to automate the statistical monitoring process. JMP scripts significantly reduce the data analysis time.
Published on ‎03-24-2025 09:06 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:57 AM
Start:
Tue, Sep 13, 2011 09:00 AM EDT
End:
Fri, Sep 16, 2011 05:00 PM EDT
