Custom Application Development with the JMP® Application Builder
Dan Schikore, PhD, Software Developer, JMP
The JMP Scripting Language (JSL) is a rich language for automating, customizing and extending JMP. The JMP Application Builder is a new drag-and-drop environment for custom application development in JMP. Reports, display boxes and data filters can be arranged for display in multiple windows without requiring any scripting. Applications are broken down into modules, which operate in private namespaces to avoid outside interactions. For more complex applications, JSL can be added to the Application and each Module to customize the behavior. The JMP Application Builder is integrated with the new JSL Debugger and supports deployment of applications through add-ins, files, data tables and scripting. In this talk, I will demonstrate the development of a custom application, from creation and debugging through deployment of the completed application.
0 Comments
Published on ‎03-24-2025 09:05 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:56 AM
Start:
Mon, Sep 10, 2012 09:00 AM EDT
End:
Thu, Sep 13, 2012 05:00 PM EDT
