Daniel Valente, PhD, JMP Senior Product Manager, SAS
Brady Brady, JMP Technical Enablement Engineer, SAS
It is always nice to show your data analysis results from JMP directly in JMP. But in some cases, you may need to prepare a slide deck to present your information to others. And if you aim to publish findings in a print journal or article, it is often necessary to produce high-quality vector images of your JMP graphs to satisfy submission guidelines. In this session, we will demonstrate best practices for getting JMP graphs and reports into both Keynote on the Mac® and PowerPoint on Windows. We will cover generating vector images from JMP suitable for submission to print journals using both the Mac and Windows versions of the software. Finally, we will cover producing high-resolution bitmap graphics from JMP and adjusting the output DPI of images.
Published on ‎03-24-2025 09:01 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:45 AM
Start:
Mon, Sep 14, 2015 09:00 AM EDT
End:
Sat, Sep 17, 2016 05:00 PM EDT
