David Trindade, PhD, Fellow and Chief Officer of Best Practices, Bloom Energy
In analyzing reliability data from repairable systems, engineers often will use the JMP Life Distribution platform to model the times between failures. However, such an analysis, which neglects the time order of the observations, can lead to incorrect conclusions. The Recurrence Analysis platform in JMP provides techniques for correctly modeling reliability data from repairable systems. This talk will include examples of improper application of the life distribution approach to reliability data and the discovery analysis resulting when the appropriate recurrence analysis methodology is applied. The talk will also highlight the limitations of mean time between failure (MTBF) as a reliability summary statistic and illustrate how MTBF values reported in the literature can be artificially inflated.
Published on ‎03-24-2025 08:56 AM by Community Manager Community Manager | Updated on ‎03-27-2025 09:43 AM
Start:
Mon, Sep 14, 2015 09:00 AM EDT
End:
Sat, Sep 17, 2016 05:00 PM EDT
