JMP System Requirements (Windows)
  JMP 18; JMP Pro, Version 18
  OS (64-bit releases only):
Windows 11
Windows 10 (except Windows 10 S edition)
Windows Server 2022
Windows Server 2019
Windows Server 2016
CPU: 64-bit: x64 processor only; ARM processors are not supported
RAM: 4 GB or more recommended
Drive Space: 2 GB (plus up to 250 MB for additional software below, if not already installed)
Recommended Display: True (32-bit or more) color with resolution of 1024x768 or greater; video card with hardware accelerated 2D and 3D drivers recommended
Database: UNICODE compliant ODBC 3.5 or higher (required only if connecting to database)
Additional Required Software (included with JMP installer):
Microsoft .NET Framework 4.8
Microsoft Visual C++ 2022 Redistributable
JMP add-in for Excel requires one of the following:
Office 365
Excel 2021
Excel 2019
Excel 2016
Other Compatible Software
(not required):
SAS VIYA
SAS 9.4
R open-source statistical software releases 2.9.1 or higher
MATLAB R2012a (version 7.14.0) or higher
Minitab (version 18 or lower)
Supported Languages:
English, Japanese, Simplified Chinese, Korean, French, German, Italian, Castilian Spanish
  JMP 17; JMP Pro, Version 17
Windows 11
Windows Server 2022
Windows Server 2019
Windows Server 2016
Note: JMP presentation virtualization license needed for use on Windows Server operating systems.
Microsoft Visual C++ 2019 Redistributable
Office 365
Excel 2019
Excel 2016
Excel 2013
(not required):
SAS VIYA
SAS 9.4
A Python distribution from python.org from release 3.7.x or higher
  JMP 16; JMP Pro, Version 16
Windows 11 (JMP 16.1 and above)
Windows 8.1 (except the RT edition)
Windows Server 2019
Windows Server 2016
Windows Server 2012 R2
Browser:
Chrome or a more modern browser required for viewing HTML5 output, JMP Public output and Help.
Microsoft Compatibility Solution - Internet Explorer 11.0 or greater - required for using Tip of the Day, Open as Web Page
Office 365
Excel 2019
Excel 2016
Excel 2013
Excel 2010
(not required):
SAS VIYA
SAS 9.4
SAS 9.3
A Python distribution from python.org from release 3.7.x through 3.9.x.
  JMP Live 18
Windows Server 2022
Windows Server 2019
Windows Server 2016 (x64)
CPU:
Minimum CPU Cores/Threads: 8
Recommended CPU Cores/Threads: 16
Drive Space: 4 GB (plus up to 250 MB for additional software below, if not already installed)
Browser:
Apple Safari (latest stable version)
Google Chrome (latest stable version)
Microsoft Edge on Chromium (latest stable version)
Mozilla Firefox (latest stable version and latest Extended Support Release version)
Note: JMP recommends using the latest versions of these browsers for enhanced performance and security. Your browser must be enabled for JavaScript.
  JMP Clinical 18
Windows 11
Windows Server 2022
Windows Server 2019
Windows Server 2016
RAM: 8 GB minimum, 16 GB or more recommended
Drive Space: 128 GB minimum, 256 GB or more recommended
Supported Languages: English, Japanese, Simplified Chinese
  JMP Genomics 10
Windows 7 SP1 (except Windows 7 Starter and Windows 7 Home Basic editions)
Windows Server 2016 (x64)*
Windows Server 2016
Windows Server 2012 R2 (x64)*
CPU: Pentium 4 or equivalent processor, 1.86+ GHz minimum, faster recommended
Browser:
Microsoft Compatibility Solution – Microsoft Edge
True color with resolution of 1024x768 or greater; video card with hardware accelerated 2D and 3D drivers recommended
Database:
Microsoft .NET Framework 4.6.1
Microsoft Visual C++ 2017 Redistributable
Azul Zulu Version 8.38 - minimum JRE of Oracle version 1.7 needed to connect JMP with SAS software
Other Compatible Software (not required):
Python 3.6.5
*JMP server license needed for use on Windows server operating systems.
