Accessing the Original Analysis Script from the Report Window that Creates It
A lot of the work that we do with JSL is modifying or extracting pieces from generated JMP Reports.  Sometimes, however we need to go backwards from a Report and work with the underlying analysis itself.  This actually involves moving between the different "layers" of a JMP Report - the Report Layer, and the Analysis Layer.  This is easily done when you can start at the Analysis Layer and assign a variable to it.  This recipe covers how to do the reverse - start at the Report Layer and access to the Analysis Layer that generated the report.
Ingredients:
  • Report Objects
  • Platform Objects
Sample Data Tables — Big Class.jmp
Difficulty — Medium
Video Time  — 4:42
Steps:
  1. Open the Big Class.jmp sample data set and run the Distribution table script to follow along.
    // Open Big Class and run the distribution report
    dt = Open("$Sample_Data/Big Class.jmp");
    dt << Run Script("Distribution");
  2. Get a reference to the window.  This will give you access to the report layer.
    // Get the window reference
    reportName = "Big Class - Distribution";
    reportReference = Get Window(reportName);
  3. Subscript into the first outline box (the one with the report level red triangle menu).
    // Subscript into the first outline box
    reportOB = reportReference[OutlineBox(1)];
  4. Send the Get Scriptable Object message to the outline box.
    // Get the associated analysis layer object
    analysisReference = reportOB << Get Scriptable Object;
  5. Check that we have accessed the Analysis Layer Object.
    // Check that we've accessed the analyis layer object
    // by displaying the script for the report
    // (i.e. the result of Save Script To...)
    reportScript = Char(analysisReference << Get Script);
    Show( reportScript );
This can be done in one step:
// this could also all be done in one step
analysisReference = Get Window( "Big Class - Distribution" )[Outline Box( 1 )] << Get Scriptable Object;
// check the connection
reportScript = Char( analysisReference << Get Script );
