JSL Cookbook
JSL Cookbook Subject Index
Subject
Recipes
Application Builder
Create a Parameterized Application with Application Builder
Generalizing an App Builder Parameterized Application
Associative Arrays
Accessing Information using REST/API – Getting Started
Colors
Modify a Report Based on Analysis Results
Data Table Objects
Join 2 Tables and Create a Subset
Debugger
The JSL Debugger – Basics
The JSL Debugger – Next Steps
Dialogs
Using a Dialog Box to Create a Tailored Report
Enhanced Log
Build a Tailored Report using Messages
The Script Window – Basics
Expression Handling
Dynamically Change Graph Builder Chart Type Depending on Variable Modeling Type
Running a Platform without Knowing the Number of Names of Columns
Graph Builder
Graph Objects
Add a Summary Statistic Graph Reference Line that Response to Local Data Filter Changes
Input-Output
Concatenate CSV Files Selected by User
Lists
Platform Objects
Accessing the Original Analysis Script from the Report Window that Creates It
Report Objects
Row State Handler
REST/API
Script Editor
Using the Script Widow – Next Steps
Scripting Index
String Manipulation
User Input
Workflow Builder
Automate the Creation of a Simple Dashboard using the Workflow Builder
Adding Unrecorded Steps to a Workflow
XPATH
