Byron_JMP
Automating Analyses and Reports Using Basic JMP Scripts - Slides and Files
Slides and files used in Mastering JMP webcast showing how to use JSL to automate repetitive process monitoring by implementing control chart scripts. Although the demo is a follow-up to the Mastering JMP session Tracking and Trending Manufacturing Metrics, the techniques for creating scripts by borrowing and gluing together JMP auto-generated code can be used to build scripts for any repetitive tasks.
View the video from the webcast.
Comments
THKS to your information, later will discuss with you.
glad you found it helpful
Article Tags
Contributors
