Thommy7571
One DOE for two contradictory research questions?
I want to study a chemical reaction, which occurs in the frame of a measurement as a side reaction. I want to know, 1)  which factors and which values give an optimal result and 2) which values give a minimal result.
It seems that I have two possibilities:
Two DoE Plans for each question
One DoE Plan for both.
However, to get both results, all kinds of parameters need to be studied thoroughly and
this gives a lot of experiments in view of the eight parameters of the measurement.
Also, in the latter case scanning experiments appear to be difficult, since two reactions need to be targeted and
not only one. What would you recommend?
Sincerely
Thommy7571
Re: One DOE for two contradictory research questions?
Not enough information about the situation to provide any specific advice.  Question: is the optimal result of the reaction independent from the minimum result of the reaction?  Is there one response variable that measures the "quality" of the reaction?  Is it a continuous variable?  Are you trying to pick a winner or are you interested in understanding causal structure?
Most situations require sequential investigation to understand.  Start with a large design space (e.g., lots of factors at bold levels) and iterate.  How many experiments you will need depends on your current subject matter knowledge.
Thommy7571
Hallo,
sorry for the delay, It belongs to the work and I am on hoildays:
Of course there i sa chemical rate law which connects both results but as long as it cannot be determined by th JMP I guess I need to answer that such results are independent, even if a lhigh value for the maximum automatically means a lower value for the minimum value. However it is not clear if there are no parameters which give a Gaussian distribution of the result.
Yes there is one parameter, which will be simply the ratio of the two signal intensities of the two compounds to maximize:
either compund I is maximized - and compound 2 minimized - or the other way round.
Variables are continuous. I don't know much about the possibilities of JMP. If I have the winner is fine. If there is a way to get chemical parameters - kinetics - from JMP that wood be even better. I would automatically have both results.
The problem is that I have 9 parameters but I only know from two more or less which influence they should have. I have already some measurements but without any special design behind. I neither know if I can use them to prepare my DOE experiment nor how (if yes).
