Predictive Modeling and Machine Learning Fundamentals with Modern Industrial Applications
NOTE: Workshops require an additional fee. We are in the midst of incredible and exponential growth of applications of large language models and machine learning across all branches of science and engineering. This workshop covers several intriguing examples where applications of modern methods can bring key new insights and walks step-by-step through a few practical use cases, illuminating good analysis principles along the way. The XGBoost, Torch Deep Learning, and JMP Assistant add-ins provide easy and powerful access, covering a broad range of predictive modeling problems for image, unstructured text, and tabular data. A primary goal is to provide you with increased know-how and confidence in applying newer ML models with best practices.
Please note: This workshop requires JMP Pro. We can provide access to a virtual lab to use on your laptop if you do not have JMP Pro installed at the time of the workshop.
This workshop is not included with your registration fee. The fee will be charged in addition to your conference registration fee.
Info
Fees:
    100
    90-min workshop
    200
    180-min workshop
Presenter
