Tutorial - Using Functional Data Explorer to Make Sense of Sensor Data (US 2018 410)
Chris Gotwalt, JMP Director of Statistical Research and Development, SAS
Scientists and engineers are dealing with more and more data streamed from device-based sensors or batch process monitors. Hundreds or thousands of such data streams can create a large volume of data, very quickly, posing a unique set of challenges. No matter what your industry, common difficulties exist with this type of data: simplifying and cleaning up messy data, removing outliers and building models that characterize an underlying function or relate a continuous data stream to measures of performance, such as yield, defect rate or product quality. With Functional Data Explorer in JMP Pro 14, you can take advantage of this functional data, easily performing data cleanup, transformation, visualization and feature extraction. Ultimately, this allows you to more easily build models you can use to design experiments, characterize processes or make predictions.
Published on ‎03-24-2025 08:51 AM by Community Manager Community Manager | Updated on ‎04-08-2025 09:07 AM
Start:
Mon, Oct 8, 2018 09:00 AM EDT
End:
Fri, Oct 12, 2018 05:00 PM EDT
