12-15 March
Honeycomb Designs Add-In (new version)
There is a necessity for plant breeders to accurately phenotype plants and select effectively for both yield potential and stability in the absence of the confounding effects of competition.
Prognostic breeding accomplishes this goal by evaluating plants for i) plant yield potential and ii) plant stability in the same generation.
The product of plant yield and stability is the plant prognostic equation which predicts the crop yield potential of single plants (Fasoula 2006, 2013).
Accurate measurement of the plant prognostic equation is accomplished by using the honeycomb selection designs which form moving replicates and moving grids to allocate entries under comparable environmental conditions (Fasoula 2008, 2013).
JMP software was developed as a useful tool for the construction of the honeycomb designs and the analysis of data in order to effectively select the best entries and the best plants within entries in prognostic breeding.
This poster presents an updated version of the earlier version developed by Mauromoustakos et al (2006). It describes how we addressed the overall objective, to improve the Haskell cultivar thru successive breeding experiments, in using two experiments. The objective of the first experiment was to exploit the genetic variation for seed yield within the soybean cultivar “Haskell” and select the best 20 plants (Fasoula 2013). The objective of the second experiment was to evaluate and select among these lines for seed yield and other agronomic traits using a replicated (R21) honeycomb design (the best selected 20 lines from experiment 1 plus the Haskell check as Entry 21).
Repicated Honeycomb Design (R21)Repicated Honeycomb Design (R21)
