R&R and P/T
There are some confusions between %R&R and %P/T in JMP variability chart output
Replace the wording Gauge R&R in the first output, because when spec are entered, the third column is % of tolerance and the figure for the line Gauge R&R and the column % of tolerance is actually a P/T (and several Customer believe it is the %R&R which does not use the tolerance in the calculations, AIAG definitions).
Why is this idea important?
because confounding %R&R and %P/T is a real issue (in the first table of the journal, 2.17 is %P/T, not %R&R
