The AddIn provides a GUI to automatically create normalized columns.
e.g.: weight normalized by weight of a typical 15year old boy/girl.
Open the GUI via Cols/normalize , adjust all settings as you like, then click Apply.
GUI
Details
Columns can be used as:
Settings
The new column can be produced by (just) calculating the values or by generating a Formula Column.
Default setting: Formula which is calculated once and then deactivated.
Add-in developed and tested using the following system configuration:
Developed with JMP 17.1.
Tested with JMP 16-17.2.
This AddIn was triggered by a comment from @mia_stephens in a reply to a Wish List entry:
known restriction:
- subset selection doesn't work for columns with value labels (will be fixed with the next release)
to do:
- add lag option
