Graph Builder Toolbar
hogi
Level XI
Purpose
If you use Graph Builder often, the Graph Builder toolbar extension will help you by adding shortcuts to the report toolbar so that you can
  • Open and close the Control Panel
  • Toggle the legend on and off
How to Use
  • Control Panel on/off. Toggle the Control Panel mode on/off (makes point plots much nicer)
  • Legend on/off. Toggle the legend display on/off.
  • Send to PPT. Shortcut to send the graph to an open Powerpoint presentation (Windows only. Requires an open Powerpoint presentation)
  • Linecut (in beta). Generate a linecut from a heatmap plot. Development and documentation of the code via the Community: Line Profile in JMP?
  • Cycle Group X/Y/Wrap Font Size. Change the font size of Group X/Group Y/Wrap labels
    implementing @ms's idea from Reduce font size for wrapped graph builder headings?
    Unfortunately, this is possible via hacking the Preferences!
    Here is a wish from 2019 to fix it in the future: Right-click to change Group font and font size
Note: I like it to have the report toolbar on the left of the window. To get it there, just right-click the toolbar and select Location > Left.
System Configuration
Add-in developed and testing using the following system configuration.
Windows
JMP 16
JMP 17
Special Considerations
PowerPoint is required to use the send to PowerPoint toolbar item. This requires a call to the operating system using the JSL function Run Program.
PowerShell is required to use the send to PowerPoint toolbar item.
Special Thanks
@jthi : Thanks for your great suggestions
