Wei1
JSL script Save Values in Model Driven Multivariate Control Chart
Hi!
How could I write JSL to "Save Columns -> Save Values" for saving t-square in Model Driven Multivariate Control Chart?
try use
obj << T Square Plot( SaveValues );
still cannot savevalues in new column T2
thanks
Re: JSL script Save Values in Model Driven Multivariate Control Chart
This seems to work fine for me (using JMP 17.2)
dt = Open("$SAMPLE_DATA/Quality Control/Flight Delays.jmp");
mdmcc = dt << Model Driven Multivariate Control Chart(
	Process(:AA, :CO, :DL, :F9, :FL, :NW, :UA, :US, :WN)
mdmcc << T Square Plot(Save Values);
Wei1
Hi jthi,
My JMP version is 17.0
I will try to update
Thanks
