The Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals.
To use:
The sledge rules
Is anyone having issues with Slides into Journal?
Just to add to this. I use Export as PNG and then use All slides. I have to export into a folder at the root of C:\. From there, a new folder is created and I point add-in to that folder for PNG files.
I used it recently and had no problems. I saved my slides as .jpg images and placed the needed images (I didn't need all of slides inserted to my journal) in a folder as required by the add-in's Slides to Journal utility.
Thanks for this Add-In, inspired from @Jason_Wiggins
Just record a short 2mins video to clear some of the doubts above and also sharing my experienc using it
Thank you Brady, it's great. @brady_brady
Soon after I post above video, realized that the picture should re-name as "Slidex" then all pictures in
Hello,
Thanks for this really nice add-in.
I have trouble inserting my slides. I exported the slides from Powerpoint in jpg in a folder and point to this folder. the first slide appear but I cannot go to the next one. This error message appear
Does any one knowing what cause this error?
Thanks
Marie
@ruthhummel Ruth Hummel demos importing slides into a Journal. Watch this video https://www.youtube.com/watch?v=BVfAmeEpgn8 starting at about time 8:22.
Hello @brady_brady ,
For some time now I've been having a problem trying to import slides into a journal. The slides are saved separately as png, I've followed the correct steps (I'm used to doing this and I've reviewed the video just in case). I also saved the folder directly in C:.
with the following error message :
" Cannot subscript Display Box in access or evaluation of 'sb[ /*###*/pictbox(2)]' , sb[/*###*/pictbox( 2 )] at line 81 in C:\Users\fraemr\AppData\Roaming\SAS\JMP\Addins\com.jmp.brady.JournalTextSledgehammer\SlidesIntoJournal.jsl "
I'm using 17.1.0 (wanted to try on v16 but I don't have access anymore).
Emmanuel
@mgerusdurand and @Emmanuel_Romeu , the error you are seeing is most likely a result of trying to advance a slide with the journal locked. Please unlock the journal and see whether this error persists.
Cheers,
Brady
Hi @brady_brady
the error persists with Lock journal unselected (or selected : it was not selected but I tried both just in case).
Emmanuel.
Hi @Emmanuel_Romeu,
Please send me your journal and your powerpoint deck via e-mail and I will investigate.
Thanks,
Brady
Hello,
Just following up on that.
Did you manage to find the cause?
Thanks,
Marie
hi,
did you find the cause I have the same problem.
thanks
