See how to:
Create, format and navigate rows and columns from data grid and table panel
Use column properties to set data types (numeric, character, row state, expression) and modeling types (continuous, ordinal, nominal, multiple response, unstructured text, vector)
Understand the way JMP analyzes data based on data and modeling types
Use multiple response character data; hide and/or exclude rows and understand what each means
Use red triangle hot spots to sequentially disclose analysis and formatting options
Group table script to organize them in table panel
Format columns
Understand the Distribution column exception related to incorrect data or analysis type
See how JMP graphically links multiple response data on some graphs to show relationship between values
Use shortcuts to move between graphs and reports
Save replayable analysis scripts to data table panel
Add metadata (notes, list check, value labels, value ordering, formula, formula preview results) to a group of columns
Recode in place to new column; save recode formula to auto-update column when new observations are added; group similar values to same recoded value; recode to value labels to simplify graphs
Subset rows from graph to new unlinked data table; use data view to subset rows linked to data table; exclude data from report using local data filter; label individual rows for displaying in all graphs
Note: Q&A included at times 10:52, 34:35 and 42:21.
In this short video, Alisa Hunt-Lowery shows how to compare data tables using the JMP 16 enhanced interface:
Resources
