New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
JMP Academic Webinar - Intro to JMP for Students
Published on ‎12-08-2022 04:20 PM by Staff | Updated on ‎06-21-2023 03:37 PM
Post questions or comments below. Download the JMP Journal file in the Attachments section to the right.
Webinar Overview
JMP is no-code data visualization and analysis software used across a wide range of industries and academic disciplines. If you're a student who will be using JMP in your coursework or research, this webinar will teach you everything you need to know to begin using the software. We provide an overview of JMP's interface and range of tools, and then show how to import data, make graphs, perform analyses, and save results. We also show the top resources to use when you're wondering how to get JMP to do what you want.
If you're a student who's new to JMP, let the JMP Academic team help you get started with the software. It might even help you land a job someday.
Helpful Links
Quick JMP tutorial videos and guides: https://www.jmp.com/en_us/learning-library.html
Other JMP resources for students: https://www.jmp.com/en_us/academic/students.html
Start:
Tue, Jan 24, 2023 01:00 PM EST
End:
Tue, Jan 24, 2023 02:00 PM EST
0 Comments
