New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
JMP Academic Webinar - Building, Diagnosing, and Interpreting Linear Regression Models
Published on ‎06-16-2022 03:14 PM by Staff | Updated on ‎06-21-2023 03:36 PM
Post questions or comments below. Download the JMP files in the Attachments section to the right.
Webinar Overview
Linear regression modeling is one of the most widely used statistical tools in academic research. Applying this foundational technique effectively requires a degree of technical knowledge regarding model construction, diagnostics, and interpretation. This webinar, which is appropriate for novice to intermediate linear modelers, will help you build the technical knowledge to be able to confidently use linear modeling in your work. We'll see how to: build standard least squares regression models with a mix of continuous and categorical factors, diagnose and address common problems with regression models, and interpret model parameters appropriately.
Helpful Links
Free 30-day trial: www.jmp.com/try
JMP Academic Program: www.jmp.com/academic
Free Teaching materials: www.jmp.com/teach
Contact the JMP Academic Team at academic@jmp.com.
Start:
Wed, Jul 27, 2022 02:00 PM EDT
End:
Wed, Jul 27, 2022 03:00 PM EDT
0 Comments
