Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Match JMP probit analysis with PROC PROBIT from SAS, including LACKFIT option. SAS will assume normal or T distribution depending on the lack of fit test result. LoD and CI results from the two platforms can vary based on this difference.
