Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to use Accelerated Life Testing (ALT) to evaluate reliability. Register for June 5 webinar, 2pm US Eastern Time.
Fit model allows the user to set up and launch an analysis but not close the launch window. This is useful when iterating through many versions of a model. Add this check box (but leave it unchecked by default) to every platform.
We have many platforms that allows this in JMP, but we are not planning to add this as a general design feature. Also, in my most JMP platforms now, a red triangle option exists to "Relaunch Analysis", which will bring up the previous launch dialog with the settings that were specified for that platform.
