☑ cool new feature
☐ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
edit: first part shifted to Expression Indexing: How to climb the Expression Tree?
Thanks @jthi for providing a solution:
Via Extract expr a user has the possibility to search and extract parts of Expressions.
The function provides a pattern search and returns the first match.
Even Wildcards are possible
A mixture of Display Tree Indexing and Data Table Indexing - just for expressions:
A more precise read access via:
myExpr=Expr(gb = dt << Graph Builder(
Size( 437, 413 ),
Graph Spacing( 4 ),
Variables( X( :height ), Y( :weight ), Y(:height), Overlay( :sex ) ),
Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) )
//instead of:
Arg(Arg(Arg(Arg(Arg(myExpr,2),2),3),3),1)
// I want to use:
myExpr[2][2]["Variables"]["Y"(2)][1]
//assign // send // Graph Builder // Variables
// or like it's possible for Display Trees:
myExpr["Variables"]["Y"(2)][1]
Where it gets really cool: write access similar to what's is possible via Data Table Indexing:
myExpr["Variables"]["Y"(2)][1] = Expr(:height);
Like Substitute - but in a different dimension!
[edit]
And maybe the best application of Expression Indexing: Insert Into , e.g.:
Insert Into ( myExpr["Variables"], Expr(Y(:age)))
Why is this idea important?
With the Power of Expression Indexing, Expression Handling in Jmp will get easier
more wishes submitted by
