This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Created:
Sep 21, 2020 02:52 PM
| Last Modified: Oct 24, 2023 01:59 PM
See how to:
Examine tree structure
Use Scripting Index
Show properties to identify objects used in reports and messages that can be sent to objects using JSL
Build.dialog structures to capture user input, including button boxes, check boxes, radio boxes, freeform text edit boxes, number edit boxes, combo boxes and slider boxes
See how to:
Capture user input and customize graphs based on input
Understand difference between graph boxes and frame boxes
Line up boxes for vertical alignment, add text to a frame box display text on graphs, use mousetrap to select points and show coordinates on graphs, add a button box to control graphs, and dynamically create check boxes
Create column list boxes and list boxes
See how to:
Modify and operatie on values from a JMP report, including how to add columns to a report, capture report results into a log, capture a table as a matrix and capture a report as a data table
Automatically update reports in third-party packages, such as MS Power Point, when the data refreshes
