videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
tr_text = "这篇帖子最初是用 lilicon-trans-text 书写的,已做计算机翻译处理。当您回复时,文字也会被翻译成 lilicon-trans-text。".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
} catch (e) {
} else {
tr_text = "此消息已翻译,以方便您使用!";
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '708108' && "TkbArticlePage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '708108') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if ("TkbArticlePage" == "IdeaPage") {
if (value == '708108') {
if ("TkbArticlePage" == "TkbArticlePage") {
if(subTkbElement){
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+''+lTex+'';
var tagHLink = labelEle.querySelectorAll(".label")[j].querySelector(".label-link").href;
} catch(e){} */
try{
var labelsLength = document.querySelector(".LabelsList").querySelectorAll(".label").length;
var labelSnapshotLength = lingoLXML.snapshotLength;
if (labelsLength == labelSnapshotLength){
for (var k = 0; k < lingoLXML.snapshotLength; k++) {
//trLabels.push(lingoLXML.snapshotItem(i).textContent);
if (k != 0) {
//trLabelsHtml = trLabelsHtml + ',';
//diffVariable = kValue
try{
if(labelEle.querySelectorAll(".label")[k]){
tagHLink = labelEle.querySelectorAll(".label")[k].querySelector(".label-link").href;
trLabelsHtml = trLabelsHtml + '' + lingoLXML.snapshotItem(k).textContent + '';
else {
catch(e){
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
labelEle.querySelector("ul").innerHTML = "";
labelEle.querySelector("ul").innerHTML = trLabelsHtml;
// trLabels = trLabels.split(",");
// trLabels = reverseArr(trLabels);
// cELabels = labelEle.querySelectorAll(".label");
// //cELabels = reverseArr(cELabels);
// for(var cE=0; cE < trLabels.length; cE++) {
// if(trLabels[cE]){
// cELabels[cE].querySelector(".label-link").text = trLabels[cE];
/* V 2.0:3 = Store not translated reply id */
if (lingoRSXML.snapshotLength == 0) {
if ($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
/* Replace Reply/Comment Body with translated Body */
for (var i = 0; i < lingoRBXML.snapshotLength; i++) {
var newBody = lingoRBXML.snapshotItem(i);
/* try {
var cPTags = newBody.getElementsByTagName("p");
var searchText = "
