gail_massari
What does p-value coloring in JMP mean?
In JMP, a p-value between .01 and .05 is colored red; less than .01 is orange; greater than .05 is black.  Color-coding can help when you are analyzing a number of different effects at once and want to look in reports for visual cues of  statistical significance.
P-values help us make inferences about populations from the sample we analyze. They relate to the null hypothesis - which is that there is no effect in the population from which a sample was taken.
In simple terms,a low p-value suggests that the null hypothesis is wrong, and that there really is an effect out there in the population.
For example, a sample of 50 individuals might show a correlation between two variables. The null hypothesis states that there is no correlation out there in the whole population, but a low p-value for the correlation suggests that the null hypothesis is wrong (i.e., there really is a correlation in the population). Thinking of p as standing for probability, one might think of a low p-value as indicating that the result we see in our sample would be low probability if there weren’t actually an effect out in the population.
Statisticians typically consider a p-value  ≤ 0.05 statistically significant. In some cases, people look for p-values <.01.
Ross Metusalem @Ross_Metusalem  explains:
Article Tags
Contributors
