jmp.com/help has a special search box that makes it easy and efficient to search JMP documentation and support materials. After you locate the help you need, moving forward through the documentation using the NEXT button provides a quick tutorial, sometimes with examples you can work through using sample JMP files and with links to related information, algorithms JMP uses to calculate stats, and more.
