Submit your abstract to the call for content for Discovery Summit Americas by April 23. Selected abstracts will be presented at Discovery Summit, Oct. 21- 24.
How can I retain the desired look of my axes when using Graph Builder Column Switcher?
Column settings are cleared when switching between columns. To retain them during column switches, first make your adjustments on the axis you want to format and then right-click the axis and select Save to Column Property. When you do this your custom settings are saved as a property of the column in the data table, which means any time you use that column in a graph (or switch back to it in column switcher) your customized settings will repopulate
