How can I change the order values are displayed on graphs?
Value Ordering lets you change the order. Mary Loveless, @MaryLoveless, says changing the order is easy and experiment is the best way to understand how the changed order displays (top to bottom, bottom to top, left to right, right to left) on different graph axes.  Highlight column in table, right click, then COLUMN PROPERTIES>VALUE ORDERING.
Often, the value on the top of your list is on the bottom of the graph, and vice versa.
The above order displays like this in Distribution and Graph Builder Y-Axis:
