KingGrey
Visitor
Journals to HTML Maintaining beautiful format
Hi
I have a distribution that is saves as PDF, but now I would like to save this Jounal as HTML as it provides a smaller file size.
When I do this the format is very different looking compared to the PDF version.
I would like to know how:
1) use JSL to write content from a distribution to  a Journal > saved as HTML, while keeping the format
2) Insert some kind of HTML code that will make HTML tables look good.
Could you please provide me some examples.
thanks.
scwise
Re: Journals to HTML Maintaining beautiful format
KingGrey,
See if this helps:
Here is an older community log that talks about how to use JMP Scripting (JSL) to create Interactive HTML.
https://community.jmp.com/t5/JMP-Blog/How-it-works-Interactive-HTML-in-JMP-11/ba-p/30392
Also here is a log on exporting data tables to HTML via scripting:
https://community.jmp.com/t5/JMP-Scripts/Export-Data-Table-to-HTML/ta-p/23410
Lastly here is a log on saving journals to HTML:
https://community.jmp.com/t5/Discussions/Saving-journals-as-HTML/td-p/85
