Registration open for Discovery Summit Europe. User Group Members benefit from a 25% discount with the code: DSEUgroup24
KingGrey
Visitor
Journals to HTML Maintaining beautiful format
Hi
I have a distribution that is saves as PDF, but now I would like to save this Jounal as HTML as it provides a smaller file size.
When I do this the format is very different looking compared to the PDF version.
I would like to know how:
1) use JSL to write content from a distribution to  a Journal > saved as HTML, while keeping the format
2) Insert some kind of HTML code that will make HTML tables look good.
Could you please provide me some examples.
thanks.
1 REPLY 1
scwise
Re: Journals to HTML Maintaining beautiful format
KingGrey,
See if this helps:
Here is an older community log that talks about how to use JMP Scripting (JSL) to create Interactive HTML.
https://community.jmp.com/t5/JMP-Blog/How-it-works-Interactive-HTML-in-JMP-11/ba-p/30392
Also here is a log on exporting data tables to HTML via scripting:
https://community.jmp.com/t5/JMP-Scripts/Export-Data-Table-to-HTML/ta-p/23410
Lastly here is a log on saving journals to HTML:
https://community.jmp.com/t5/Discussions/Saving-journals-as-HTML/td-p/85
