This is an open group. Sign in and click the "Join Group" button to become a group member and start posting.
Community Member
Journals to HTML Maintaining beautiful format
I have a distribution that is saves as PDF, but now I would like to save this Jounal as HTML as it provides a smaller file size.
When I do this the format is very different looking compared to the PDF version.
I would like to know how:
1) use JSL to write content from a distribution to  a Journal > saved as HTML, while keeping the format
2) Insert some kind of HTML code that will make HTML tables look good.
Could you please provide me some examples.
Re: Journals to HTML Maintaining beautiful format
See if this helps:
Here is an older community log that talks about how to use JMP Scripting (JSL) to create Interactive HTML.
Also here is a log on exporting data tables to HTML via scripting:
Lastly here is a log on saving journals to HTML:
